06-14-2007 06:44 AM - edited 03-03-2019 05:26 PM
I have 2811 routers at two different site connecting with MPLS.
I would like to use the Frame Relay as a back up. Can I use WIC 2T on these routers? Is WIC 2T compatible for 2811? The router is version 12.4. Is there any special configurations for this set up?
Thank you.
06-14-2007 06:53 AM
Yes you can use the WIC-2T in the 2811. As you probably do not "see" any MPLS configuration, and are only an user of carrier service, it will be just a traditional routing configuration.
06-14-2007 07:01 AM
Thank you. I will give it a shot.
