2811 question
I am using WIC 1DSU-T1 V2 cards in my 2811 Router. Is this WIC compatible with E1 lines say in the UK?
I just want to make sure before I order additional ones to deploy over seas.
1 REPLY
Re: 2811 question
Friend,
Those are T1 cards and are not comaptible with E1's
You should either be looking at VWIC2-1MFT-T1/E1 or VWIC2-1MFT-G703 which can take either a T1 or an E1 input
Narayan
106
