Community Member
2811 rebooting on it's own...
I have a 2811 running IOS 12.4(5). About every other night between 9pm and 11pm it reboots. Is there any known rebooting issue with a 2811 or that revision of IOS?
Re: 2811 rebooting on it's own...
Can you paste a sh tech-support output ? It is possible that the router crashes and "sh version" output should show the reason for reload.
Community Member
Here's the 'sho tech-support' capture
VIP Purple
a bug search using the information you have posted did not reveal any bugs that would apply to your situation. I wonder if your problem could simply be related to some sort of power outage, especially since it happens at apparently almost the same interval. Or maybe there is a very heavy traffic load, or some other, possibly user-invoked, process happening at that time. If possible, can you set up syslogging and log to an external device ? The problem is that the router logs are cleared when the router is reboot, so all the potentially relevant information is lost...
GP
184
