Webcast-Catalyst9k
2811 redundancy
My current configuration has R1's s0 interface connection to a patch panel.
However, I would like to install a redundant 2811 (R2' s0)to the same patch panel. I'm not sure if it requires a second cable or a y-cable?
The configuration should still allow the standby router to see rip updates and user traffic.
help
Hall of Fame Super Gold
Re: 2811 redundancy
S0 ? to a patch panel ?
Which interface is that, check properly.
Re: 2811 redundancy
It is the serial0 interface of router.
Re: 2811 redundancy
Serial interface don't go to patch panels usually. You cannot do Y-cables with serial interfaces, and you will need a second link to feed a second router with.
152
