08-29-2006 08:06 PM - edited 03-03-2019 01:48 PM
I have a new 2811 router and WIC1T.
I found the line "clock rate 2000000" on configuration. It's no needed because this will connect to CSU.
But I can't remove that line. There is no error msg when I issue "no clock rate". But after that, I still be able to see "clock rate 2000000".
What can I do for it? Please help me asap.
Solved! Go to Solution.
08-29-2006 08:41 PM
Yes, do connect the cable to the CSU and then issue the "no clock rate 2000000" command.
Arul
08-29-2006 08:18 PM
Do you have cable attached to the serial interface.
Attach a DTE Cable to the interface and then do a "no clock rate 2000000" and the clock rate command should go away.
Arul
08-29-2006 08:34 PM
Thank you for your response.
I didn't connect router to CSU, but I attached DTE cable.
But there is still "clock rate 2000000" after I've issued "no clock rate".
Shoud I connect it to CSU for delete clock rate?
Thanks.
08-29-2006 08:41 PM
Arul
08-29-2006 10:04 PM
Thank you so much, Arul.
I solved this as your saying.
