08-19-2014 02:28 PM - edited 03-05-2019 06:53 AM
We use an old Cisco 2821 at the internet edge for initial inbound traffic filtering. In an attempt to block certain provider networks that are a source of SPAM, we attempted to apply an ACL that included a range of addresses as follows:
access-list 110 deny ip host 198.20.160.0 0.0.31.255 255.255.255.255
This command was shorted to the following in the running config:
access-list 110 deny ip host 198.20.160.0 any
The ACL does not seem to work, as we are still seeing SPAM slip through on this range.
Any help is greatly appreciated.
Thank you for your time.
Solved! Go to Solution.
08-19-2014 06:39 PM
Hi ,
Your ACL syntax will deny only host 192.20.160.0 .
if you look below
You have specfied source as host (host 198.20.160.0 )
destination host as any (inalid network and subnet mask -0.0.31.255 255.255.255.255 )
You want to block which subnet or network , given me source and destination subnet ?? . Will recorrect the ACL
Sandy
08-19-2014 07:02 PM
ACL's are in the form of :
access-list [###] [permit or deny] [protocol] [Source IP Network] [Source wilcard mask] [Destination IP Network] [Destination wildcard mask] [port (optional)]
When you use the keyword "host" that equals a wildcard mask 0.0.0.0 and then you do not need to put in the wilcard mask, just the host IP.
In your example, access-list 110 deny ip host 198.20.160.0 0.0.31.255 255.255.255.255, you was telling the router that you wanted to deny packets from a source single IP of 198.20.160.0 with a wildcard mask of 0.0.0.0 and a destination of 0.0.31.255 255.255.255.255 which is an invalid IP and mask.
Hope this helps.
You can read this article to help more - Here
08-19-2014 06:39 PM
Hi ,
if you look below
Sandy
08-19-2014 07:02 PM
Hope this helps.
08-20-2014 06:37 AM
Thanks a ton. Copied an existing ACL and somehow totally missed the "host" keyword. That got it fixed right up.
access-list 110 deny ip 198.20.160.0 0.0.31.255 any
