2851 and 48 Port EtherSwitch Module issue
techsupport
router# copy flash: xmodem
Ok guys the above command is not working at all it should have coppied the image to the etherswitch module but it just renames the file and copy it in the router flash im pasting both the outputs.
It should work like that:
Router# copy flash: xmodem
**** WARNING ****
x/ymodem is a slow transfer protocol limited to the current speed
settings of the auxiliary/console ports. The use of the auxiliary
port for this download is strongly recommended.
During the course of the download no exec input/output will be
available.
Proceed? [confirm]
You are prompted for the source filename and destination filename:
Source filename [loader_bs.img]?
Destination filename [loader_bs.img]?
You are prompted for the Cisco EtherSwitch service module slot number:
Service Module slot number? [1]:
Step 8 dir flash:
Example:
switch> dir flash:
Displays a list of all files and directories in flash memory on
the service module.
Step 9 boot flash: image
Example:
switch> boot flash:c3825-i5-mz.050404
Boots the Cisco EtherSwitch service module image if all
files and directories are in flash memory on the service
module.
Command or Action Purpose
Cisco EtherSwitch Service Modules Feature Guide
Troubleshooting the Cisco EtherSwitch Service Module Software
70
Cisco IOS Release 12.2(25)SEC
You are prompted for the service module interface number. Accept the default:
Service Module interface number? [0]:
You are prompted to confirm the buffer. Accept the default:
1k buffer? [confirm]
You are prompted for the max retry count. Accept the default:
Max Retry Count [10]:
You are prompted to confirm the transfer to the Cisco EtherSwitch service module:
Xmodem send on slot 2 interface 0. Please be sure there is enough space on receiving side.
Continue? [confirm]
The following appears when the image is downloaded to the service module:
Ready to send
file...........C!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
262144 bytes copied in 101.744 secs (2577 bytes/sec)
And this is whats happening with me.
yourname#copy flash: xmodem
Source filename [c3750-ipservicesk9-mz.122-35.SE5.bin]?
Destination filename [xmodem]?
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]
Copy in progress...CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
8638247 bytes copied in 21.604 secs (399845 bytes/sec)
and #Show flash:
14 8638247 Feb 28 2009 08:39:40 +00:00 c3750-ipservicesk9-mz.122-35.SE5.bin
15 8638247 Feb 28 2009 10:05:04 +00:00 xmodem
6 Replies 6
royalblues
Level 10
Level 10
Why are u trying to do xmodem, is the software corrupted?
All you need to do is copy the software on to the routers flash and set the boot parameters
eg.
router#copy tftp: flash:
Then use
service-module interface slot/port session
boot flash: image
Narayan
Yeh the IOS on the etherswitch is corrupted, and every time i take session it takes me to the ROMMON.
copy tftp: xmodem
You are actually renaming the file to xmodem
The flash shows that it has a 3750 image so just go into the service module and try to boot
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/miragenm.html#wp1768057
Narayan
Leo Laohoo
The command you are trying to use (copy flash: xmodem) tells the appliance to copy A file from flash and NAME it as "xmodem".
Yeh i know that, but if you refer the guide it should ask me about the location of ether switch but it isn't.
