Community Member
2851 Router - Firewall replacement??
We are currently running a PIX 515E behind a 2851 router balancing two internet pipes via BGP.
It has been recommended to us that we upgrade the PIX to the ASA line.
Is there a good reason not to use the Firewall/VPN capabilities available in the 2851 and eliminate the additional box?
We have two point-to-point VPN tunnels to remote offices running PIX501's and a handful of users accessing client VPN, though that may change if we can do SSL VPN.
Any advice would be greatly appreciated!
1 REPLY
Hall of Fame Super Gold
Re: 2851 Router - Firewall replacement??
Hi, firewall/vpn services on the router work comprehensively and effectively, like or better of what you get using a separate device.
You will find that using the router for that generally gives a simplified configuration and addressing plan, easier troubleshooting, more versatility and scalability.
111
