Community Member
2851 router in rommon
hi
my router is in rommon mode how can i get back to normal operation its not taking the confreg 0x2102 also
i think the image is got corrupted
how can i upload new image.
ur suggestion will be highly appreciated
regards
Re: 2851 router in rommon
Try the following command in ROMMON
rommon 1 > confreg 0x2102
rommon 2 > reset
If it still boot in ROMMON, try this link http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094a0b.shtml
If the first link doesn't fix the problem, try this link
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Community Member
when i do
dir flash
the router is showing an error
open error=-66
dir:cannot open device flash
I think this error message displays when the flash is empty or the file system is corrupted. Try the second link I provided to you to upload IOS using XMODEM
Community Member
hi
thanks for ur speedy reply but still m getting the same error.
Contact your vendor then, the flash maybe faulty. The error -66 looks like hardware, can't find it in Cisco web
Community Member
i think this is the matter as i used one router flash this is working not giving this error.
i m trying with other router flash which is 32mb only mine was 64 but the ios will come in this as its only 28mb.
i will make this router running and when will get new flash will replace well thanks for your reply .
i will assaign points whn router is up and running.
600
