2901 txload shows 255/255 even with no traffic
Hi all,
I am experiencing a strange problem with a 2901 router that I just installed. I replaced a 1760 router with a new 2901 router and all seems to be working but for some reason the txload on interface g0/0 and interface multilink1 show 255/255 even though there is no traffic going over to this router. I have dual routers at this location and at the moment I have all traffic going over to my other router a 2821.
reliability 255/255, txload 255/255, rxload 1/255
Thanks in advance for any inputs/suggestions !!!
D.
Please post the show version output from 2901.
Vivek
Hi Vivek, please see "show version" command output below. Thanks !! I appreciate your help !!!!!
sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T, RELE
ASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 15-Nov-11 22:10 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
SAUK-2901-1 uptime is 1 hour, 35 minutes
System returned to ROM by reload at 22:00:47 Central Mon Jan 23 2012
System restarted at 22:02:32 Central Mon Jan 23 2012
System image file is "flash:c2900-universalk9-mz.SPA.152-2.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX154784KM
2 Gigabit Ethernet interfaces
2 Serial interfaces
1 terminal line
2 Channelized T1/PRI ports
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2901/K9          FTX154784KM
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
Can you share your interface g0/0 and interface multilink1 config...!
KodandaRao - Please rate helpful posts
Hi Kodandarao, please interface config below. Thanks !! I appreciate your help !!!!!!
interface GigabitEthernet0/0
description To MDF-3750-48-1 Fa1/0/3
no ip address
load-interval 30
duplex full
speed 100
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.28.3 255.255.255.0
standby 1 ip 172.16.28.1
standby 1 priority 105
standby 1 preempt
standby 1 track 1 decrement 10
ip policy route-map Set-IP-QoS
interface GigabitEthernet0/0.2
encapsulation dot1Q 29
ip address 172.16.29.3 255.255.255.0
standby 29 ip 172.16.29.1
standby 29 priority 105
standby 29 preempt
standby 29 track 1 decrement 10
interface GigabitEthernet0/0.3
encapsulation dot1Q 30
ip address 172.16.30.3 255.255.255.0
ip helper-address 172.16.28.5
standby 30 ip 172.16.30.1
standby 30 priority 105
standby 30 preempt
standby 30 track 1 decrement 10
interface Multilink1
description MLPPP to Verizon MPLS
ip address 152.177.161.2 255.255.255.252
ip wccp 61 redirect in
ip wccp 62 redirect out
ppp multilink
ppp multilink group 1
service-policy output Voice-Over-Wan
interface Serial0/3/0:0
no ip address
no ip redirects
encapsulation ppp
load-interval 30
no keepalive
ppp multilink
interface Serial0/3/1:0
no ip address
no ip redirects
encapsulation ppp
load-interval 30
no keepalive
ppp multilink
Re: 2901 txload shows 255/255 even with no traffic
Hi Dtran,
Please change your interface bandwidth rate as mentioned below. and let us know the status.
BW 100000 Kbit
Router(config)# interface G0/0
Router(config-if)# bandwidth 100000
Router(config)# interface Multilink1
Txload and Rxload:
You can measure transmit and receive traffic on any interface of  Cisco Router or Switch. You can find txload and rxload fields of Cisco  IOS’s command sh interface <> output and it will  be in a number from 0 to 255. You then use that to calculate your  bandwidth. txload and rxload roughly measure the amount of traffic  passing out of and into an interface, respectively, relative to its  perceived bandwidth. As an example, if it is a 100 Mbps Fastethernet  interface, txload is 126/255 it means transmit traffic from this  interface would be 50 Mbps. If rxload is 63/255 it means receive traffic  on this interface would be 25Mbps.
I too am seeing this on new 2901's running the same image with no traffic. I opened a TAC case and they pointed me to bug CSCtw90305
Yup, the issue was bug related. I downgraded mine IOS version to 151-3.T3 and the issue went away.
thanks
D.
4452
