02-04-2012 06:20 AM - edited 03-04-2019 03:08 PM
migrating from 2821 to 2921 cisco router, it's not possible configure "frame-relay traffic-shaping" and "no ip mroute-cache" in to serial interface.
Any one know is these features are already active on 2921 router or how can I configure them ?
Follow the 2821 configuration...
interface Serial0/1/0
bandwidth 1000
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
frame-relay lmi-type ansi
no shutdown
interface Serial0/1/0.9 point-to-point
description to Sing Serial0/0/0.54
bandwidth 1000
ip address 173.27.70.42 255.255.255.252
no ip mroute-cache
ip ospf network point-to-point
no arp frame-relay
frame-relay interface-dlci 9
class FR_QoS
frame-relay payload-compression packet-by-packet
map-class frame-relay FR_QoS
frame-relay cir 54000
frame-relay bc 10000
frame-relay mincir 54000
frame-relay fragment 310
service-policy output RTU_64
policy-map RTU_64
class Platinum
set dscp ef
priority 20 2000
class Gold
set dscp af32
bandwidth 20
class class-default
fair-queue
set dscp default
ip nbar custom Firewall tcp 18192
ip nbar custom TCP104 tcp 2404
ip nbar custom UDP104 udp 2404
ip nbar custom tcpiccp tcp 102
ip nbar custom udpiccp udp 102
ip cef
class-map match-any Gold
match protocol ospf
match protocol telnet
match protocol ssh
match protocol Firewall
class-map match-any Platinum
match protocol UDP104
match protocol TCP104
match protocol tcpiccp
match protocol udpiccp
Best Regards in advance,
Luca
02-04-2012 11:15 AM
Why mroute is no longer supported:
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_03.html#wp1054798
What error do you get when applying FRTS on the interface?
02-05-2012 07:50 AM
Many Thanks.
For "no ip mroute cache" I see the MFIB command but I don't understand the use of this command (...not yet).
FRST is not supported on serial interface.... the command is not present and I don't know if thare is another feature to activate it.
The IOS version is 15.2(1)T1.
Bye, Luca
02-05-2012 03:35 PM
Have a read through this
http://www.cisco.com/en/US/docs/ios-xml/ios/wan_frly/configuration/15-0m/wan-afrt-shp-ic.html
Eugen
02-06-2012 02:00 AM
Hi Eugen,
I've read the document, but the problem is that FRST feature is not present (Is it not supported ???) in the 2921 serial interface configuration.
The problem is not the FRST documentation..... is the FRST 2921 supporting.....
Have you any other suggestions ?
Bye, Luca
02-06-2012 04:42 AM
Hi Luca,
I have found the right link for your IOS 15.2
Eugen
02-06-2012 07:38 AM
I've solved with Child/Parent policy activation (but I must test it).
I need configure a new policy-map for class-default traffic in this way:
policy-map Child_RTU_64
class Platinum
set dscp ef
priority 20 2000
class Gold
set dscp af32
bandwidth 20
class class-default
fair-queue
set dscp default
policy-map Parent_RTU_64
class class-default
shape average 54000 10000 !They are the value of cir and bc on the map-class frame-relay FR_QoS of before
service-policy Child_RTU_64
service-policy output Parent_RTU_64
bandwidth 1000
no ip mfib forwarding input !replace no ip mroute-cache
no ip mfib forwarding output !replace no ip mroute-cache
no arp frame-relay
frame-relay interface-dlci 9 CISCO
class FR_QoS
Only a very strange result........ applying the "frame-relay payload-compression packet-by-packet" command in the serial subinterface compare the word "CISCO" in the "frame-relay interface-dlci 9" string.
Very strange...... I'm investigating because in the other peer... CISCO is not present....
Bye, Luca
02-06-2012 04:43 PM
Good to hear you fixed the main problem.
Eugen
