09-26-2013 03:51 PM - edited 03-04-2019 09:09 PM
I have a new 2921 router with 2 VWIC3-2MFT-T1/E1 Cards in EWIC slots 0 and 1 (Configured for T1). The strange thing is that ports 0 and 1 on Slot 0 and port 0 on the card in Slot1 show only the amber AL light (as expected), however port 1 on the card in Slot 1 shows both the amber AL light but also a green light on the CD/LP light. I am just setting this router up and don't have anything plugged into any of the T1 ports and a show controller T1 shows the port down with loss of signal as expected (see below).
The strange thing is that if I do a shut no shut on the T1 controller the green light goes out. Do you think this is aesthetic or an actual problem with the T1 card or port itself?
I just upgraded to IOS Version c2900-universalk9-mz.SPA.151-4.M6 but am not sure if this showed up immediately after this upgrade or not.
Has anyone else run into this?
Show controller T1
T1 0/1/1 is down.
Applique type is Channelized T1
Cablelength is long 0db
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Failure LOF State:Failure
Version info FPGA Rev: 08121917, FPGA Type: PRK4
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (849 seconds elapsed):
6 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 849 Unavail Secs T1 0/1/1 is down.
Solved! Go to Solution.
09-26-2013 04:24 PM
I dont worry to much on that. What would be interesting to know is what if you had a T1 loopback cable connected to those cards.
09-26-2013 05:09 PM
That means that your T1 cards are working as expected.
09-26-2013 04:24 PM
09-26-2013 05:04 PM
I plugged in a T1 loopback cable and it linked right in my alarm light went out and the cd/lp light stayed green and when I pulled the cable the alarm came back on and the green cd/lp light went back out. Here is the show controllers output after plugging my loopback cable in. Sounds like a bug to me. I think I'll avoid that port except in an emergency just to be on the safe side.
T1 0/1/1 is up.
No alarms detected.
AIS State:Clear LOS State:Clear LOF State:Clear
Data in current interval (444 seconds elapsed):
5359 Line Code Violations, 5 Path Code Violations
0 Slip Secs, 1 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 425 Unavail Secs
Total Data (last 3 15 minute intervals):
10664 Line Code Violations, 12 Path Code Violations,
0 Slip Secs, 3 Fr Loss Secs, 5 Line Err Secs, 0 Degraded Mins,
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 2674 Unavail Secs T1 0/1/1 is up.
No alarms detected.
09-26-2013 05:09 PM
09-26-2013 05:12 PM
Thanks for the advice. I just found it strange that the green light comes on every time I reboot the switch.
