2950 switch is not working
I have a 24 port 2950 switch, It is not booting , unrecognised characters are coming on the console when it try to boot up, Fan is not working as well, could anyone tell is the switch is out of order now or I am missing something,
you advise required.
regards
Usman
1 REPLY
Re: 2950 switch is not working
Hello Usman,
The fan might get stuck with dust - the 2950 are out there for a couple of years.
Regarding the unrecognised characters, I suggest doing the same what has been suggested for similar problems in this forum: try setting the speed of your COM port to each value in the range from 1200bps up to 115200bps and see whether you can gain access to the console. Also make sure that your console cable is OK.
By the way, what is the status of the LEDs on the front panel? Does the switch appear to be booting? After a few minutes, do at least these LEDs revert to the normal state?
Best regards,
Peter
111
