Community Member
2950 switch
what does it mean "no spanning-tree optimize bpdu transmission"? on switch 29xx switch?
What will happen if it is disable?
rdgs
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 2950 switch
Hello Anita,
>> "If the STP is enabled, this feature should be enabled
as I told in my first post leave it exactly as you see
no spanning-tree ...
I think in this way the switch behaves normally by automatically relying BPDUs received on its root port out of all of its ports in forwarding state.(vlan specific)
the command is present in some command references of higher models like c6500.
I agree that is not well documented
Hope to help
Giuseppe
Re: 2950 switch
Hello Anita,
this is a default and you should be fine without enabling it.
When enabled the command changes the way the switch treats the BPDUs regarding their propagation: the switch to optimize BPDU transmission can do something different from normal relay behaviour.
I didn't find it in command reference
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/command/reference/cli2.html#wp3076679
Hope to help
Giuseppe
Community Member
Re: 2950 switch
Hi Giuseppe,
I also cannot find it from cisco web site, it seems that it is undocument.
"If the STP is enabled, this feature should be enabled". Above statement is correct or not?
rdgs
Re: 2950 switch
Hello Anita,
Hope to help
Giuseppe
172
