2951 Router is hanged
My 2951 router is stuck at startup, I have attached the screenshot of problem. Need guidance its urgent.
Thank you.
Imran
VIP Purple
Are you able to get into
Are you able to get into ROMMON?
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/appendixCrommon.html#pgfId-1014464
If so, we can try some more recovery options.
If not, then if you have a Cisco Maintenance contract, like SmartNet, contact TAC and get an RMA.  If not, then you'll probably be buying a new router ...
NO i can not get in ROMMON
NO i can not get in ROMMON mode, it is just stuck over here. What I did was I loaded new IOS in flash using 2811 router and then inserted flash back in 2951 but of no use
VIP Purple
I think you are up for
I think you are up for hardware replacement sorry.
by this you mean Flash
by this you mean Flash replacement or i need to buy a new router
VIP Purple
New router I'm afraid.
42
