04-07-2012 03:33 AM - edited 03-04-2019 03:56 PM
Hi Every One.
we are using 2960 cisco switch asn we are trying to configure port security.
we are able to configure MAC base port security, but unbale to configure IP base port security.
can any one guide us can do IP base port security like MAC port security.
if not which switch will support IP and Mac base port security.
need help.
Solved! Go to Solution.
04-08-2012 01:34 PM
You can implement IP security on switch by using ACLs (access lists). If that's what you are looking for - I don't know what are you trying to achieve.
Best regards,
Jan
04-08-2012 11:24 PM
I think what you're looking for is IP Source Guard .
You can restrict based on the IP DHCP Snooping database and/or static "ip source binding.." entries.
Cheers.
05-02-2012 09:05 AM
DHCP Snooping with IP source guard should help. If you have static IPs then you can create static mappings.
Check the below documentation for clear reference:
Nandan Mathure
04-08-2012 02:45 AM
Explain "IP base port security" - what do you want to do?
04-08-2012 01:34 PM
Best regards,
Jan
04-08-2012 11:24 PM
Cheers.
04-09-2012 01:18 AM
What do you mean by IP base port security???
you mean Access control list? denying specific source to specific destination?
Manouchehr
05-02-2012 07:09 AM
Dear All.
I am Looking for the Switch port secutiy based on IP, like when users change static IP Address the switch port should either disable or go in to error disable mode, like port security work with MAC base port security.
05-02-2012 09:05 AM
Nandan Mathure
