2960 upgrade
Dear All
I have 2960 switch with light image.is it possible that I upgrade the IOS to standard image?
regards
1 REPLY
Hall of Fame Super Bronze
Re: 2960 upgrade
Please refer to:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_qas0900aecd80322c37.html
Q. Can I upgrade or downgrade a Cisco Catalyst 2960 Switch between the LAN Base and LAN Lite IOS images?
A. No. Cisco Catalyst 2960 Series Switches cannot be upgraded from LAN Lite to LAN Base and cannot be downgraded from LAN Base to LAN Lite.
HTH,
__
Edison
Please rate helpful posts
238
