Community Member
2960G 12.2.55-SE9 in public inet; config
I would like to put a 2960G with version 12.2.55-SE9 in public inet and therefore have setup this config based on cisco hardening sheet. Any recommendations are welcome if this is "enough" or even bad things are set (except of http secure-server being available).
Thank you very much in advance.
Martin
version 12.2
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
no service dhcp
hostname n-ext1-swi01
boot-start-marker
boot-end-marker
enable secret 5 <secret>
username <user> privilege 15 secret 5 <secret>
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
clock timezone MET 1
clock summer-time MET recurring last Sun Mar 2:00 last Sun Oct 3:00
system mtu routing 1500
no ip source-route
ip icmp rate-limit unreachable 100
ip dhcp bootp ignore
no ip domain-lookup
crypto pki trustpoint TP-self-signed-811688448
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-811688448
 revocation-check none
 rsakeypair TP-self-signed-811688448
crypto pki certificate chain TP-self-signed-811688448
 certificate self-signed 01
  30820243 ........ ........ ........ ........ ........ ........ ........
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh source-interface GigabitEthernet0/11
ip ssh version 2
 switchport mode access
 no lldp transmit
 no lldp receive
 no cdp enable
interface GigabitEthernet0/24
 no lldp transmit
 no lldp receive
 no cdp enable
interface Vlan1
 ip address 213.xxx.xxx.xxx 255.255.255.192
 no ip route-cache
ip default-gateway 213.xxx.xxx.xxx
no ip http server
ip http access-class 10
ip http authentication aaa
ip http secure-server
access-list 10 remark *************************************
access-list 10 remark limit access
access-list 10 permit 217.xxx.xxx.xxx
access-list 10 permit 213.xxx.xxx.xxx
access-list 10 deny   any
no cdp run
line con 0
line vty 0 4
 access-class 10 in
 exec-timeout 720 0
 transport input telnet ssh
 transport output telnet ssh
line vty 5 15
 access-class 10 in
 exec-timeout 720 0
ntp server 92.53.103.108 prefer
end
Everyone's tags (1)
114
