3 x WIC-1DSU-T1-V2 1 circuit MPPP
If the telco is providing 3 x t1 on one circuit ppp. Can we run MPPP by installing 3 x WIC-1DSU-T1-V2 and terminating the circuit to one device?
Re: 3 x WIC-1DSU-T1-V2 1 circuit MPPP
hi
i feel you are gonna use 3 WIC cards to terminate 3 T1s and you want them to be logically bundled in your device its very much possible to do so but do revert whether the destination points for all the 3 T1s are same or whether it differs.
if the you are having them with the same location then you can do the bundling on both the locations without any probs but if its connecting to different locations then its not possible to have them in bundle.you will have to use them as induvidial pipes between your locations..
BTW in which router model you are trying to put these models out there ?
regds
They are going into a 2811.
3xT1 aggregated in one connection. The Telco will be presenting one interface.
speed 3xT1 in one circuit ------[]Router
I still need 3 cards for this dont I for MPPP?
Yes. unless you use something like a VWIC-2MFT-T1. you can settle with two wics.
120
