Community Member
3560 and object tracking
All, I am trying to do object tracking with two ISPs on a 3560. My site has a 3560 as the core, and I have two internet connections that go out to two separate ISPs, via two seperate routers. Id like to see if anyone has a config they would share that would show that load balancing is being done on the 3560, while if one link goes down, the other takes the load. Id planned on using two default routes for this. Can anyone help with a config?
I have looked at the enhance object tracking pdf. Still need some help on it. Thanks in advance.
Green
Re: 3560 and object tracking
Pretty sure the 3560 doesn't even support object tracking. I think you need at least 3750.
Community Member
The 3560 manual mentions enhanced object tracking, but not sure to what scale. Any idea?
123
