05-16-2006 03:53 PM - edited 03-03-2019 12:43 PM
Hi there,
Does anyone know how to resolve this issue:
_____________________________________________________
rommon 2 > xmodem c3620-i-mz.122-26a.bin
Do not start the sending program yet...
device does not contain a valid magic number
dir: cannot open device "flash:"
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c3620-i-mz.122-26a.bin ...
Erasing flash at 0x30000000sector erase failed at location 0x30000000, status 0x
2000
flash sector will NOT erase...aborting
rommon 3 >
Cheers,
Daniel
05-22-2006 12:35 PM
The error "Do not start the sending program yet...device does not contain a valid magic number dir:cannot open device "flash:"" is related to either the corrupted IOS image or bad Flash.Following are the steps which u can try if the memory is as per the requirement:
1) Reset the Flash
2) download the new image
05-23-2006 01:11 PM
Thanks Martin for your reply.
The problem is that I can't access the flash at all.
You're right about the valid magic number explanation, but I coulnd't find a resource explaining the Bad sector message.
I've changed the flash and downloaded a new image which I've verified its md5 still to no avail.
