12-08-2007 03:47 AM - edited 03-03-2019 07:50 PM
My 3620 router is communicating perfectly well in my OSPF lab and I have checked the current configuation register is 0x2102 in using "show version" command, but I am getting this message below
"Smart Init is disabled. IOMEM set to: 25"
I am wondering there is a way to overcome this issue?
I would be greatful for any help
Bob.
Solved! Go to Solution.
12-08-2007 05:27 AM
Hi Bob,
IOMEM seems to be set in your configuration. If your router is booting perfectly and this message is your concern, you can disbale it by configuring "no memsize iomem 25". This will enable SmartInit and it will take care of memory reservation.
Nagendra
12-08-2007 05:27 AM
Hi Bob,
Nagendra
12-09-2007 07:35 AM
Dear Nagendra
Thanks for reply.
I have two links with different ISP's and both the links (512Kbps)are terminated on seprate seprate cisco routers(2811).Currently we are useing one link and another one link is new.I want to loadsharing and redundency between them.Right now i am not using BGP (routers are configured in simple manner).Here is a my client cost matter,so i want .My presant network seneriois like this:-
Internet Ri(Isp1)-- Layer 3 switch (working here like as a simple switch)---firewall 1 (cisco ASA5510)--firewall 2(ciscoASA5510)---Lan.
on firewall-1 remote and site to site vpn configuered, one dmz.
my lan is in 172.16.1.xx series,dmz in 172.16.4.10, and after 172.16.1.30 is using for desktop ,192.168.x.x is managment ip.
Right now i have one another internet link(512kbps) from different ISP.
So please advise me how can i do that (loadbalancing with redundeny). once i was trying oer but not successfull due to IOs image (c2800nm-ipbasek9-mz.124-11.T.bin)and
ISP's AS.it can be possible through natting,and ACL. or ple give me any idea with OER or any solution.If possible ple send me also sample configuration.
If u want any info ,ple tell me .
Please reply me as soon as possible , i am waiting for your reply
Thanks and regards,
sujeet.
12-08-2007 09:12 AM
Naikumar,
This has certainly enabled it as I used the "no memory-size iomem 25" command in the privileged mode.
Great many thanks Naikumar!
Bob.
12-08-2007 10:15 AM
Naikumar,
Please forgive me for the above error, I'v used this command in the global configuation mode.
Bob.
