3640 CPU hog: 100% for hours. "RBSCP process " ?
mcroft
Recently I had an instance where a 3640 became unusable for about 3.5 hours.
The CPU was at 100%.
It appeared that the process "RBSCP Background" is the boooger that hogged the entire CPU's resource.
I find little information on the cisco.com site that explains this process. All I can find is information regarding a "Rate Based Satellite Control Protocol", however, this has never been used or configured. So not sure why the process is running and hogging.
All the information I have is this ...
Aug 1 21:19:12.471: %SYS-3-CPUHOG: Task is running for (12492)msecs, more than
(2000)msecs (3125/3124),process = RBSCP Background.
-Traceback= 0x604BBB50 0x604B98D8 0x604B9CB8 0x604C02C4
I am running Version 12.4(13b)
Any help or info on this process would be greatly appreciated ...
Many Thank
Matt
Also,
check out the CPU ... whooooow.
333666666669999999999969999999999999999999898998999909
345235442554888774424333433396615579767778899972915229989909
100 ** **############# **###*
90 ########**# *#################*******######
80 ########### ###################*#**########
70 ** ***#############################################
60 ***################################################
50 *##################################################
40 *##################################################
30 **####################################################
20 ######################################################
10 * *######################################################
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
111 1 111
00078877809765 515241990003
000141589044664182090130008
100 *** * ***
90 #** *** ***#*
80 ##* ******* ***#*
70 ##*********** ***#*
60 ##*******#**** **##*
50 ##*******#**** * * * **##*
40 ##*******#**** * * * **##**
30 ##*******#**** * * * **###*
20 ##*******#**** ***** **###*
10 ###**######### **#****####*
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
spremkumar
Level 9
Level 9
hi
can you paste the output of show rbscp all here ?
do u hve any tunnels enabled in your router ?
regds
Thanks for response.
Here's the output, basically nothing as its not running. Also, I can confirm there are no tunnels runnning. Its just three interfaces running in a very simple design (NO tunnels, NO dot1q tags, nothing)
Router#show rbscp all
Router#
Router#show rbscp statistics
Router#
Matt
Hi Matt
Is your CPU still hogging up ?
Also what about the RBSCP process utilisation now ?
Do you have any logs available with you during the hog up condition of your router ?
regds
Hey,
Unfortunately not.
The cpu was crazy last night.
Its now settled down and is running fine.
CPU for RBSCP is now ...
Router#show proc cpu sorted | include RBSCP
94 414268 1392189 297 0.16% 0.14% 0.16% 0 RBSCP Background
Weired ...
The only log information I have is the CPU hog syslog msg and the traceback .. that's it.
I am stumped to why this service is being used and why this happened.
thanks
matt
