Webcast-Catalyst9k
3640 Router - Compatbility
Can 3640 Router be configured with NM-1E2W and VWIC-2MFT-G703 Card.?
regards
R.Sundara Rajan
1 REPLY
Purple
Re: 3640 Router - Compatbility
The VWIC-2MFT-G703 is not supported within a NM-1E2W on a 3640. However, you can use one of the following:
NM-1FE2W
NM-1FE1R2W
NM-2FE2W
NM-2W
The following doc has more info:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
Hope that helps - pls rate the post if it does.
Paresh.
103
