07-24-2008 03:47 AM - edited 03-03-2019 10:53 PM
I'm currently running a 3640 at our corporate gateway, which generally works fine for our needs. Under the current configuration, the router uses about 40+% cpu peak.
Lately I've been playing with nbar, and of course this really hammers the cpu when the traffic load is high. I've read of folks recommending a 2811 as a replacement in this situation. Is the 2811 really strong enough? I would have expected the 3800 to be the recommended upgrade. I do have a 2811 on hand, but I don't want to replace the 3640 only to be in the same situation with the 2811. How do these two really compare in performance?
Thanks.
Solved! Go to Solution.
07-24-2008 06:59 AM
My personal experience has shown that when certain features are enabled (firewall, IPS, NBAR) on the 2811 it does bog it down as well.
To allow for growth, I would go with the 2821. The 2821 is a big jump from the 2811 in my opinion. I have a few 2821s running NBAR, NetFlow, QoS, Firewall & IPS and average CPU usage is 5%.
07-24-2008 06:59 AM
07-24-2008 09:45 AM
NBAR/NetFlow/QoS is the direction I'm going so this info is great. Thanks.
07-24-2008 03:27 PM
