3725 issue
Hi all
my router keeps restarting after compressing the image and showing other common information.
I tried to boot it from ROMON but same result.
den I checked the dir flash: ,it shows me the IOS and boot flash:(IOS file)..but still keep restarting.
I think IOS is corrupted so should I use xmodem to send the IOS from pc to router or there is some other way.
Hall of Fame Super Bronze
Re: 3725 issue
Does it show corrupted while doing a dir?
It can also be a bad PCMCIA
Check out this link for options and suggestions:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a008009429f.shtml
HTH,
__
Edison.
Re: 3725 issue
Ya when I issued dir flash: then it shows me empty.
I tried again then it shows me the IOS file.
Hall of Fame Super Gold
Re: 3725 issue
Hi, usually if decompressing succeeds, the image file is not corrupted. However to reflash or boot from tftp, send a break from terminal then type tftpdnld, it will tell how to proceed to boot from tftp.
Hope this helps, pleas erate post if it does!
Re: 3725 issue
I think tftpdnld is only available in 3800 series..however I'll check this comnmand
thanx
Re: 3725 issue
The command is available on almost all platforms since 1997.
128
