3750 Escape sequence
ropethic
Level 4
Level 4
c3750E booting off wrong IOS image and need to know how to enter break sequence to get to rommon. Can someone send me the procedures. I am using hyperterminal on xp laptop. Tried ctrl c shift, ctrl fn break
nothing seems to work
Mark Yeates
Level 7
Level 7
Robert,
To enter rommon on the 3750E switch you will need to hold the mode button on the switch for a few seconds.
HTH,
Mark
Mark Yeates
Level 7
Level 7
Robert,
HTH,
Mark
Thanks, worked
one more question,
how do I cd to the directory where I want to boot image from?
I typed boot flash:c3750e....
says file not found, how can I check directory for file name
figured it out,
boot flash:/dir/file
