Community Member
3750----FLAPPING betwwen ports
I am geeting the below erros can some one suggeest me on the same
Nov 16 17:50:28.163 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 18:09:18.119 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 18:23:23.730 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 18:33:01.236 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0007.8462.e3bd in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 19:06:00.646 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:12:42.532 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:17:33.798 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0007.8462.e3bd in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:22:18.026 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0007.8462.e3bd in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:41:48.532 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 21:01:10.834 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 21:16:00.251 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
regds
ADHI
1 REPLY
Community Member
Re: 3750----FLAPPING betwwen ports
can you check whether any unidirectional link exist in your network. it a host mac address learnt through both the links. Also check is there any active standby switchover happening as well. I guess these should guide you to some hint of the resolution. Please correct me if i am wrong.
Thanks and Regards,
Srinath.M
Cable&Wireless
+91 99809 30364
285
