11-02-2007 11:32 AM - edited 03-03-2019 07:23 PM
Is there any way to load IOS from rommon ("switch:" prompt) if the bin file is missing or currupt other than xmodem? Can you boot from another stack member, or set up a tftp load like you can with a router by setting environment IP and TFTP variables, then issuing the tftpdnld command. I did try this in the lab and it takes the variables, but not the tftpdnld command.
Solved! Go to Solution.
11-04-2007 06:56 PM
In a fixed configuration switch like the 3750 xmodem is the documented recovery mechanism for software image restore. Once a software image is loaded the switch will join the stack as a part of the IOS feature for the 3750 and sync its IOS with the stack master. In regards to the rommon variables.. you can "set" quite a bit of variables, but it doesnt do much if there is nothing in the rom image to use the variables. :)
For those in a DR mode, remember the com speed on your terminal application and on the switch (switch: set BAUD 115200) when doing this or else it takes a really really long time!
For more info check out this doc.
11-04-2007 06:56 PM
11-05-2007 05:19 AM
Thanks. I was aware of the documented method, but thought I'd try my luck at finding someone that had found something else. Undocumented features can occasionally do wonderfull things but are not officially supported.
Thanks for your assistance.
