09-12-2007 08:15 AM - edited 03-03-2019 06:43 PM
If I have a 3750 stack, and I configure layer 3:
interface vlan 10
ip address 10.10.10.1 255.255.255.0
What happens if my primary switch fails?(which is where I assume those L3 definitions exist. I can comprehend the loss of ports/L2 when a switch fails but the layer three definiations...do they move to another switch of the stack?
Solved! Go to Solution.
09-12-2007 08:52 AM
Michael
The config is shared among the members of the statck. If the primary switch (stack master) fails some other switch takes over as primary (master) and the layer 3 definitions are maintained in the new primary (master). That is one of the advantages of the stack concept.
Rick
09-12-2007 08:52 AM
Michael
Rick
09-12-2007 10:56 AM
Michael
Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read about a question and can know that they will read an answer that resolved the question. I encourage you to continue your participation in the forum.
Rick
