Community Member
3750 Switch
I have just purchased several 3750 48 port switches with 4 SFP and 1 3750 12 port GIGabit switch and i can only get one side activity at a time. can some one help me out tell me what I am missing? thanks
Re: 3750 Switch
What do you mean by one side activity? Can you be descriptive and include some outputs from the switch as well?
Silver
Re: 3750 Switch
This is very common in SFP or GBICs. Try by removing and placing the SFP or by replacing SFP or GBIC with other. It will be active on both sides.
Re: 3750 Switch
one more suggestion would be just logon and check the port status/log msgs on both the switches that mite give u a lead in getting it rite...
regds
114
