3750 TCP retransmit problem
I have a problem with TCP retransmits between a server on a 4507 and clients on 3750 24 port POE.
Previously I had the following setup
Server (fibre gig connected) ->1000-> 4507 (6 port gig card) ->100-> WS-C3550-24 ->100->7204 (NPE200)->100->WS-C2924C-XL->100->PC
This ran fine, the users are uploading big Excel SS's from the server and they could open a SS in 2 mins. Sniffers on the network showed no TCP retransmits
I now have
Server (fibre gig connected) ->1000-> 4507 (6 port gig card) ->1000-> WS-C3750-24P ->100->PC
The users now take 20 mins to open the same SS and the sniffer shows 10 -30 TCP retransmits / second
When I put a sniffer on each end of the fibre between the 4500 and 3700 (mirrored to 100Mb copper ports), it indicates that I am losing packets over the link
I have check for duplex issues and there are none
I cannot see any errored packets or queue drops
I have routed the traffic over different interfaces and fibres and get the same issues
If I connect the PC to a 100mb port on the same 4500 as the server it works fine
1 REPLY
Hall of Fame Super Silver
Re: 3750 TCP retransmit problem
Chris
If the PC connected to a 100 mb port on the 4500 works fine, then it sure sounds like the issue is on the link between the 4500 and the 3750 or is in the 3750. I know that you state that you have checked for duplex issues and did not find any. But the symptoms sure do sound like a duplex mismatch - or maybe congestion in 3750. Could you post the output of show interface for the link on the 4500 and the 3750?
Rick
275
