3750E X2 10 Gig Eth Links
We will be deploying a VOIP solution with VOIP Phones and the CISCO Call Manager and hence require switches to support POE
I have selected the switch below, please let me know whether my selection is OK
Cisco Catalyst 3750E-48PD-F
48 Ethernet 10/100/1000 ports with 15.4 watts PoE on all 48 ports and 2 X2 10 Gigabit Ethernet uplinks
Secondly, we have 3COM switches with standard RJ45 Gigabit ports, how do I connect them to the X2 10 Gig ports ? What are my options...
Super Bronze
Re: 3750E X2 10 Gig Eth Links
Just make sure you have the correct power supplies for your expected POE usage.
If the 3COM ports are copper, you should be able to connect them to any of the copper ports on 3750E. If fiber, you need to use the TwinGig Converter Module, see http://www.cisco.com/en/US/products/ps7077/products_data_sheet0900aecd805bbee3.html.
Thanks for the quick reply
Are you are talking of the correct power supplies for the VOIP Phones or the 3750E Switches
Yes, the 3COM ports are copper RJ45. I'd just like to confirm, I can connect as under:
3COM Uplink Port (copper RJ45)
CISCO Any of the 48 ports (copper RJ45 ports)
Super Bronze
re: power supply - for the 3750Es
I would hope the model you want comes with the C3K-PWR-1150WAC.
As far as I know, copper to copper should be fine, as long as you have the correct pin outs on the cable (if the 3COM uplink port has the crossed pins vs. standard client port, should be able to use normal client cable)
Hi Joseph,
The WS-C3750E-48PD-EF switch comes with power supplies (see below)
48 10/100/1000 PoE ports + 2 X2-based 10 Gigabit Ethernet ports
64-Gbps, high-speed StackWise Plus stacking
68-Gbps, wire rate backplane
Field-replaceable 1150WAC power supply and fan tray
740W available for PoE, allowing full 15.4W to all 48 ports
1 rack unit (RU) stackable multilayer switch
IPv6
IP Services software feature set (IPS)
Provides full IPv4 dynamic routing
Then why do I need the "C3K-PWR-1150WAC" power supply as you mentioned ?
Super Bronze
"Then why do I need the "C3K-PWR-1150WAC" power supply as you mentioned ?"
You don't since you noted the model comes with "Field-replaceable 1150WAC power supply and fan tray ". As I wrote, I expected it to, but just want to make sure.
Hall of Fame Super Gold
No sure why someone is low rating the good answers fro Joseph, here is my 5 to correct this lamentable behavior.
Super Bronze
Thank you Paolo. That was very considerate.
The original question poster appears to be new to the forum and I suspect he was trying to rate fairly.
Exactly Paolo, Joseph has been very helpful
I was just trying to follow the chart below :-)
5 Extremely Helpful
4 Very Helpful
3 Helpful
2 Somewhat Helpful
1 Not Helpful
Another thing, we require 3 of the switches "WS-C3750E-48PD-EF", 2 in the switch cabinet on the ground floor and 1 in the data center on the first floor
Which cables do I need, I'm confused ?
LC to SC Cables for the Catalyst 3750-E Series
1. CSS5-CABLX-LCSC=
CSS11500 10-Meter Fiber Single Mode LX LC-to-SC Connectors
2. CSS5-CABSX-LC=
CSS11500 10-Meter Fiber Multimode SX LC Connectors
3. CSS5-CABSX-LCSC=
CSS11500 10-Meter Fiber Multimode SX LC-to-SC Connectors
Super Bronze
Fiber patch cables?
Choice will depend on whether you plan to use the 10 gig or gig fiber, distance, and installed fiber. Actual transceiver module choice is also impacted.
I am relatively new to Fiber and 10 Gig Uplinking Technology... Hence pardon me in advance :-)
Considering that the modules used are the ones that are default with the switch which is "2 X2-based 10 Gigabit Ethernet ports"
Now, assuming the 4 cases below:
Case 1: I use 10 Gig Fiber, cabling distance within the switch rack
Case 2: I use Gig Fiber, cabling distance within the switch rack
Case 3: I use 10 Gig Fiber, cabling distance is 30 metres
Case 4: I use Gig Fiber, cabling distance is 30 metres
In the 4 cases above, what connectors do I use ? Single Mode or Multi Mode, LC or LX or SX
All very confusing :-(
Super Bronze
I don't generally do hands on with cables, so someone else might need to advise on specifics. However, some pointers:
1) (copper) 10GBASE-CX4 Module supports link lengths of up to 15m on CX4 cable.
2) recommend using normal copper gig port, could use 1000BASE-SX SFP (for Multimode Fiber Only)
3) (new) X2-10GB-SR with correct cable or X2-10GB-LRM
4) recommend using normal copper gig port, could use 1000BASE-SX SFP (for Multimode Fiber Only)
See http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd801f92aa.html for information on X2 10 gig
See http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd8033f885.html for information of SFP gig fiber
526
