04-09-2010 09:57 AM - edited 03-04-2019 08:05 AM
I have a 3750G-24TS which does nor provide PoE. Can anyone tell me if I can add this capability to this switch and if so how?
Solved! Go to Solution.
04-09-2010 02:53 PM
Hello Kirby,
being the C3750G-24TS a fixed configuration switch and being not a modular one, POE cannot be added to it.
For modular switches like C4500 and C6500 the use of correct modules (changing linecards with POE capable ones) and an upgrade of power supplies can do the job.
if you want to add POE you need to change this switch with another device with POE capabilities.
You could use midspan injectors but the problem is that they are not easy to manage and add a device in the scenario.
Hope to help
Giuseppe
04-09-2010 02:53 PM
Hello Kirby,
Hope to help
Giuseppe
04-09-2010 05:33 PM
Giuseppe,
Thanks, I thought that was the case but couldn't find any documentation to positively verify this....Thanks for the help.
Wes
04-09-2010 05:37 PM
How many PoE ports do you require? If there's only a few, then consider using Power Injectors perhaps?
