You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
3750G Static config
Hi, Hope someone can help with this problem. I work on a site which has two totally separate networks. Each network has its own juniper Router,both of which are housed in my comms cabinet however, as it is a managed service they are soon to put us onto a single router which will host both IP ranges for the two networks. here is where I need help. I have been told to buy a Cisco 3750G layer 3 switch and configure it for the two networks from one router: The details the managed service have provided of the two current routers are:
Router 1: fe 0/0/0 25.9.5.158/27 static 25.9.26.0/24 - 25.9.5.131
Router 2: fe 1/3/0 25.8.83.129/26 static 25.8.128.0/21 - 25.8.83.136
can someone please advise on exactly what they are asking me to do. many many many thanks
  • WAN Routing and Switching
Hall of Fame Super Gold
Re: 3750G Static config
Hi, may I suggest that if you do not have networking experience, hire a reputable professional for the job.
That will avoid you a lot of frustration qne mistakes.
Agreed, I am looking at getting a consultant in, but I obviously need to be able to justify this so need to know exactly what they are trying to do i.e. is it a vlan, iproute, etc, need to know what the concept is.
You may not even need a L3 switch after all, or perhaps a smaller one than the 3750G, I think once you have a good consultant sit with both network administrators they will clarify everything and go for the better solution.
I have lots of questions. Maybe a before and after diagram showing who owns/manages what would help?
118
