Webcast-Catalyst9k
3800 IOS that supports 3DES
Hello
I have a 3825 router and I need to install an IOS that supports 3DES. I have read that 3DES is only supported on certain models that doesn't include the 3800 series. Does anyone know if this is still the case, and if there are plans to change it?
John Killilea
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 3800 IOS that supports 3DES
Hello John,
as far as I know you can install an image that supports 3DES on a C3800
the right tool is feature navigator
http://www.cisco.com/go/fn
search by platform
I see: there is a C3825 and a Cisco 3825novpn but this just means it misses the HW based encrpytion engine
even C3825 novpn supports 3DES with appropriate image example advanced enterprise with crypto.
the difference is in performance
with the HW module you encrypt more traffic without impacting cpu
Rather there are known legal constraints about where images with 3DES can be used (decided by US government for national security)
Hope to help
Giuseppe
Hello John,
search by platform
Hope to help
Giuseppe
Pretty much every platform has 3DES support. You need to look for images
that have "K9" in their name. As Giuseppe said, there are certain
restrictions and you need to have special access to download the K9 images.
If you don't have access, contact your Cisco POC and see if you can get that
access included in your profile.
NT
Hello
I got an image which sorted out the issue, thanks for you help
John Killilea
187
