3825 Half Rate T3
In the 3825 Data Sheet is states: Wire-speed performance for concurrent services such as security and voice, and advanced services at up to half T3/E3 rates. Does this mean I will only get 22.5 Mbps throughput on my HSSI module?
1 ACCEPTED SOLUTION
Super Bronze
3825 Half Rate T3
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
No, it means the 3825's performance is such Cisco doesn't guarantee wire-speed for any possible configuration.
It might handle you full rate T3 just fine (NB: likely it would); depends on your traffic and your configuration.
Bronze
Re: 3825 Half Rate T3
Yes that is right.3825 router supports up to 22.5 mbps for security,voice and advanced services.It doesnt support full T3 services.
This is not true pradeepde.
"Re: 3825 Half Rate T3
Yes that is right.3825 router supports up to 22.5 mbps for security,voice and advanced services.It doesnt support full T3 services."
This Q&A is taken from thispage:  http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps8604/prod_qas0900aecd806a2d34.html
Q.How are the T3/E3 ATM network modules positioned and deployed?
A. The Cisco 3825 and 3845 can support full T3 or E3 wire-rate performance with a single network module. The Cisco 3845 supports two network modules, but the second module is generally recommended for backup deployment, because wire-speed performance of the second interface is not supported. On the Cisco 2800 Series, full wire-rate performance is supported only on the Cisco 2851. The Cisco 2821 and 2811 are recommended for branch office deployments when less than wire-rate performance is required; for instance, 5, 10, or 20 Mbps of throughput. Figure 2 shows a common ATM deployment for the Cisco integrated services router product fami
If you look at the specs on this page: http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
you can see that it has process switching capabilty of 12.8 Mbps and CEF switching of 179.20 Mbps. This simply means that the more advanced the services are, the slower the router processes the packets. Which is you will get half the wire-speed with more advanced services, but with regular router services you are guaranteed the full T3 wire speed.
Super Bronze
3825 Half Rate T3
Disclaimer
Posting
You should please refer to the document I linked to in my post, and then refer to this line in the document (which is an official statement made by the Cisco corporation, by the way).
Super Bronze
Disclaimer
Posting
Chad you're 100% correct, the Q&A you reference says exactly what you quote about the T3/E3 ATM network module.
However, what the original poster quoted "Wire-speed performance for concurrent services such as security and voice, and advanced services at up to half T3/E3 rates", appears here: http://www.cisco.com/en/US/products/ps5857/index.html.  This too is also from Cisco.
Seems a Cisco contradiction, doesn't it?
Or maybe it's not since the SAR on the ATM interface might off-load some (interface) processing from the main CPU allowing a 3825 to indeed support an ATM T3's bandwidth which it might be unable to do with other WAN modules supporting T3s.
3825 Half Rate T3
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps4909/product_data_sheet09186a008010fba2.html
I hope this helps.If you will give me the precise module you are using i can tell you more.
Alessio
400
