12-08-2013 12:22 PM - edited 03-04-2019 09:48 PM
I recently bought a 3845 off ebay to replace my 3745
on my 3745 I used 3x NME-16ES-1G-p for intervlan routing and had the full ac+inline power setup so I was able to power my AP via POE without a injector (and one NM-1GE for connection to a D3 cable modem)
anyway using the same version of IOS I can't seem to get NAT to work, even thoguht the config is nearly the same
on the 3845 I don't have a need for the NM-1GE which was Gi 2/0 so on the 3845 gi0/0 is the wan interface
heres the ver and config
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(25d),
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 09:04 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
RLH-Router uptime is 35 minutes
System returned to ROM by reload at 09:40:57 central Sun Dec 8 2013
System restarted at 09:49:09 central Sun Dec 8 2013
System image file is "flash:c3845-adventerprisek9-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 3845 (revision 1.0) with 991232K/57344K bytes of memory.
Processor board ID FTX1444A0XP
5 Gigabit Ethernet interfaces
3 terminal lines
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
! No configuration change since last restart
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname RLH_router
boot-start-marker
boot system flash:c3745-adventerprisek9-mz.124-25d.bin
boot-end-marker
no logging buffered
no aaa new-model
clock timezone central -6
clock summer-time -0500 recurring
ip cef
ip domain name RLH-domain.net
ip name-server 10.0.3.5
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ipv6 unicast-routing
ipv6 cef
username rlh privilege 15 password 5 blabla
archive
log config
hidekeys
ip ftp username (leaving this out for now)
ip ftp password (leaving this out for now)
class-map match-all game (leaving this out for now)
match access-group 101 (leaving this out for now)
class-map match-any Xbox360 (leaving this out for now)
match ip dscp ef (leaving this out for now)
policy-map game (leaving this out for now)
class game (leaving this out for now)
set ip dscp ef (leaving this out for now)
policy-map Xbox360 (leaving this out for now)
class Xbox360 (leaving this out for now)
bandwidth 1024 (leaving this out for now)
interface Tunnel0
description Hurricane Electric IPv6 Tunnel Broker
bandwidth 30000
no ip address
ipv6 address 2001:ZZZZ:1F0E:2::2/64
ipv6 enable
ipv6 traffic-filter Internet in
ipv6 ospf 1 area 0
keepalive 10 3
tunnel source 75.x.y.33
tunnel destination 216.218.224.42
tunnel mode ipv6ip
tunnel checksum
interface FastEthernet0/0 (won't exist on 3845)
no ip address
shutdown
speed auto
full-duplex
interface FastEthernet0/1 (won't exist on 3845)
no ip address
shutdown
duplex auto
speed 100
interface GigabitEthernet1/0
description Link to NME-16ES-1G-p
ip address 10.255.255.1 255.255.255.252
ip nat inside
ip virtual-reassembly
ipv6 address 2001:470:B801:FFFF::/127
ipv6 ospf 1 area 0
interface GigabitEthernet2/0 (moving this config to GI 0/0 and the NM-1GE won't be needed and I plan to put an etherswitch here)
description Link to Comcast
bandwidth 76000
ip address 75.x.y.35 255.255.255.248 secondary
ip address 75.x.y.36 255.255.255.248 secondary
ip address 75.x.y.37 255.255.255.248 secondary
ip address 75.x.y.33 255.255.255.248
ip access-group 110 in (holding off till all's working)
ip nat outside
negotiation auto
interface GigabitEthernet3/0
description Link to NME-16ES-1G-p (number 3)
ip address 10.255.255.9 255.255.255.252
ip nat inside
ipv6 address 2001:470:B801:FFFF::4/127
ipv6 ospf 1 area 0
interface GigabitEthernet4/0
description Link to NME-16ES-1G-p (number 4)
ip address 10.255.255.13 255.255.255.252
ip nat inside
ipv6 address 2001:470:B801:FFFF::6/127
ipv6 ospf 1 area 0
router eigrp 1
redistribute static
network 10.255.255.0 0.0.0.3
network 10.255.255.4 0.0.0.3
network 10.255.255.8 0.0.0.3
network 10.255.255.12 0.0.0.3
auto-summary
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 75.x.y.38
no ip http server
ip http port 1025
ip http authentication local
no ip http secure-server
ip nat translation timeout 2
ip nat pool RLH1 75.x.y.35 75.x.y.35 netmask 255.255.255.248
ip nat pool RLH2 75.x.y.36 75.x.y.36 netmask 255.255.255.248
ip nat pool RLH3 75.x.y.37 75.x.y.37 netmask 255.255.255.248
ip nat inside source list 1 pool RLH1 overload
ip nat inside source list 2 pool RLH2 overload
ip nat inside source list 3 pool RLH3 overload
(leaving out static NAT translations till things are working, deleting this part so I don't have to filter it, leaving one here as an example of how I have them0
ip nat inside source static udp 10.0.3.10 27178 75.x.y.36 27178 extendable
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 1 deny any
access-list 2 permit 10.0.3.0 0.0.0.255
access-list 2 deny any
access-list 3 permit 10.0.4.0 0.0.0.255
access-list 3 deny any
access-list 4 permit 10.255.255.0 0.0.0.3
access-list 4 deny any
access-list 50 permit 10.0.0.0 0.0.0.255
access-list 50 deny any
access-list 101 permit ip host 10.0.3.11 any
access-list 101 deny ip any any
(Holding ACL 110 till things work so deleting it from this post)
snmp-server community (edited) RW
ipv6 route ::/0 Tunnel0
ipv6 router ospf 1
(IPv6 is working so I'm editing this part out)
ipv6 access-list Internet
ipv6 access-list VTY (IPv6 is working so I'm editing this part out)
sequence 40 permit tcp 2001:470:B801::/48 any
permit udp 2001:470:B801::/48 any
deny ipv6 any any
control-plane
banner motd Keep Out
line con 0
speed 19200 (not putting this line in yet)
line 33
exec-timeout 0 0
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 97
no exec
transport input all
line 129
no exec
transport input all
line aux 0
line vty 0 4
exec-timeout 0 0
ipv6 access-class VTY in
login local
telnet refuse-negotiations
line vty 5 15
exec-timeout 0 0
login local
ntp clock-period 17179186
ntp master 2
ntp server 128.138.140.44
ntp server 207.200.81.113
ntp server 132.163.4.101
ntp server 132.163.4.102
ntp server 132.163.4.103
ntp server 201.155.229.129
ntp server 131.107.1.10
ntp server 69.25.96.13
ntp server 207.126.98.204
ntp server 129.6.15.29
ntp server 129.6.15.28
ntp server 216.200.93.8
ntp server 64.236.96.53
ntp server 208.184.49.9
ntp server 68.216.79.113
end
Please help.
Solved! Go to Solution.
12-08-2013 04:00 PM
Ricky,
Can you please remove the secondary IP addresses from your Gi0/0 interface, then do clear ip nat translation * and try the traceroute again? You should not need to have the secondary IP addresses configured on your interface just because you are translating into them; the router is smart enough to create ProxyARP entries on behalf of addresses in the pools. I would like to remove all parts of the configuration that may interfere with the proper straightforward operation of NAT and routing.
Thank you!
Best regards,
Peter
12-10-2013 12:12 PM
Hi Ricky,
Thanks for letting us know. I suspect that stuck ARP entries are behind the entire issue: after you replaced the 3745 with 3845, the SMC kept the old ARP entries for the IP addresses in the NAT pools, breaking the connectivity. Just a guess but that would be my first shot.
Best regards,
Peter
12-08-2013 12:30 PM
Ricky,
Your current 3745 configuration indeed does not show any signs of configuration trouble, and I see no reason why it should not work on the 3845. However, to troubleshoot the 3845 behavior, we would need to see its configuration after you transferred it from 3745. Also, the output from show ip nat translation and show ip nat statistics would be necessary to see if there is at least something happening in the NAT. Can you please provide this information?
Best regards,
Peter
12-08-2013 02:01 PM
version 12.4
hostname LOGIX-Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip domain name Domain-Logix.local
ip name-server 10.0.2.6
ipv6 cef
voice-card 0
no dspfarm
interface Loopback1 (added for testing
ip address 10.254.254.0 255.255.255.255
interface Tunnel0
bandwidth 30000
no ip address
ipv6 address 2001:470:1F0E:2::2/64
ipv6 enable
ipv6 ospf 1 area 0
keepalive 10 3
tunnel source 75.148.235.33
tunnel mode ipv6ip
tunnel checksum
interface GigabitEthernet0/0
bandwidth 76000
ip address 75.148.235.35 255.255.255.248 secondary
ip address 75.148.235.36 255.255.255.248 secondary
ip address 75.148.235.37 255.255.255.248 secondary
ip address 75.148.235.33 255.255.255.248
ip nat outside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
description Link to NME-16ES-1G-p (number 1)
ip nat inside
ipv6 ospf 1 area 0
ip nat inside
ipv6 ospf 1 area 0
ip nat inside
ipv6 ospf 1 area 0
router eigrp 1
redistribute connected
redistribute static
auto-summary
ip route 0.0.0.0 0.0.0.0 75.148.235.38
no ip http server
ip nat pool RLH1 75.148.235.35 75.148.235.35 netmask 255.255.255.248
ip nat pool RLH2 75.148.235.36 75.148.235.36 netmask 255.255.255.248
ip nat pool RLH3 75.148.235.37 75.148.235.37 netmask 255.255.255.248
access-list 1 permit 10.255.255.0 0.0.0.255
ipv6 router ospf 1
log-adjacency-changes
area 0 range 2001:470:B801:FFFF::/127
area 0 range 2001:470:B801:FFFF::2/127
area 0 range 2001:470:B801:FFFF::4/127
area 0 range 2001:470:B801:FFFF::6/127
default-information originate
passive-interface Tunnel0
control-plane
line con 0
line aux 0
line 66
no exec
transport input all
line 194
no exec
transport input all
line 258
no exec
transport input all
line vty 0 4
login local
line vty 5 15
login local
scheduler allocate 20000 1000
end
12-08-2013 02:27 PM
Ricky,
Thank you for the additional data. What about the show ip nat translation and show ip nat statistics? They contain some vital data about the NAT, apart from others, whether at least some NAT translations have been created. Once again, though, the configuration appears to be correct.
I wonder - with this configuration, are you actually able to ping from your 3845 out to the internet? Can you ping the default gateway, or perhaps ping even farther? I am thinking of a remote possibility of your internet connection being tied to the MAC address of the 3745 router, preventing you from connecting the 3845 directly.
Best regards,
Peter
12-08-2013 02:41 PM
from the 3845 I can ping the internet but if I source the ping from anything but the wan interface it fails (only pasting part of nat trans as its very long)
LOGIX-Router#sh ip nat t
Pro Inside global Inside local Outside local Outside global
icmp 75.148.235.35:768 10.0.2.5:768 4.2.2.1:768 4.2.2.1:768
icmp 75.148.235.35:768 10.0.2.5:768 73.2.80.1:768 73.2.80.1:768
icmp 75.148.235.35:768 10.0.2.5:768 75.148.235.34:768 75.148.235.34:768
udp 75.148.235.35:1025 10.0.2.5:1025 10.254.254.1:161 10.254.254.1:161
udp 75.148.235.35:1026 10.0.2.5:1026 10.254.254.2:161 10.254.254.2:161
udp 75.148.235.35:1027 10.0.2.5:1027 10.254.254.2:161 10.254.254.2:161
udp 75.148.235.35:1028 10.0.2.5:1028 10.254.254.2:161 10.254.254.2:161
udp 75.148.235.35:1030 10.0.2.5:1030 10.254.254.6:161 10.254.254.6:161
udp 75.148.235.35:1031 10.0.2.5:1031 10.254.254.6:161 10.254.254.6:161
udp 75.148.235.35:1032 10.0.2.5:1032 10.254.254.6:161 10.254.254.6:161
udp 75.148.235.35:1033 10.0.2.5:1033 10.254.254.1:161 10.254.254.1:161
udp 75.148.235.35:1034 10.0.2.5:1034 10.254.254.1:161 10.254.254.1:161
udp 75.148.235.35:1035 10.0.2.5:1035 10.254.254.1:161 10.254.254.1:161
udp 75.148.235.35:1038 10.0.2.5:1038 10.254.254.2:161 10.254.254.2:161
udp 75.148.235.35:1039 10.0.2.5:1039 10.254.254.2:161 10.254.254.2:161
udp 75.148.235.35:1040 10.0.2.5:1040 10.254.254.2:161 10.254.254.2:161
udp 75.148.235.35:1041 10.0.2.5:1041 10.254.254.6:161 10.254.254.6:161
udp 75.148.235.35:1042 10.0.2.5:1042 10.254.254.6:161 10.254.254.6:161
udp 75.148.235.35:1045 10.0.2.5:1045 10.254.254.1:161 10.254.254.1:161
udp 75.148.235.35:1046 10.0.2.5:1046 10.254.254.1:161 10.254.254.1:161
udp 75.148.235.35:1047 10.0.2.5:1047 10.254.254.1:161 10.254.254.1:161
udp 75.148.235.35:1048 10.0.2.5:1048 10.254.254.2:161 10.254.254.2:161
Total active translations: 808 (0 static, 808 dynamic; 808 extended)
Outside interfaces:
GigabitEthernet0/0
Inside interfaces:
GigabitEthernet1/0, GigabitEthernet3/0, GigabitEthernet4/0
Hits: 12953 Misses: 18011
CEF Translated packets: 26158, CEF Punted packets: 9800
Expired translations: 21358
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 pool RLH1 refcount 802
pool RLH1: netmask 255.255.255.248
start 75.148.235.35 end 75.148.235.35
type generic, total addresses 1, allocated 1 (100%), misses 0
[Id: 2] access-list 2 pool RLH2 refcount 6
pool RLH2: netmask 255.255.255.248
start 75.148.235.36 end 75.148.235.36
type generic, total addresses 1, allocated 1 (100%), misses 355
[Id: 3] access-list 3 pool RLH3 refcount 0
pool RLH3: netmask 255.255.255.248
start 75.148.235.37 end 75.148.235.37
type generic, total addresses 1, allocated 0 (0%), misses 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Outside interfaces:
GigabitEthernet0/0
Inside interfaces:
Dynamic mappings:
-- Inside Source
Appl doors: 0
Normal doors: 0
Queued Packets: 0
12-08-2013 02:51 PM
Ricky,
The NAT obviously works - the entries are a clear proof.
I wonder: There seems to be a lot of entries created on behalf of the 10.0.2.5 station, with this station trying to 10.254.254.x on SNMP ports. Is this normal? The sequence of translation entries suggests that the station must have been very intense in generating that many requests and consuming quite a number of entries in your NAT table. That could account for some of the issues you are seeing.
My suggestion: let's verify whether the basic routing and very simple NAT works on your router. I suggest temporarily reworking one of your ACLs to allow NAT only from directly connected networks on your router (avoiding the 10.0.2.5 as that one seems to be aggressive at present), and seeing if the NAT works with this limited configuration. If it does, let's start adding the networks back.
Best regards,
Peter
12-08-2013 03:23 PM
Well I can't ping the internet from behind the router
ie can't ping 4.2.2.2 (Level3 anycast dns)
10.0.2.5 is my PRTG network monitor so I'll just stop it for now (maybe I forgot to update it when I switched from 10.254.254 to 10.255.255
12-08-2013 03:30 PM
ok after stopping my SNMP monitor heres the trans and stats
udp 75.148.235.35:55260 10.0.2.6:55260 65.61.188.4:53 65.61.188.4:53
udp 75.148.235.35:55260 10.0.2.6:55260 69.20.95.4:53 69.20.95.4:53
udp 75.148.235.35:55604 10.0.2.6:55604 216.239.32.10:53 216.239.32.10:53
udp 75.148.235.35:55604 10.0.2.6:55604 216.239.34.10:53 216.239.34.10:53
udp 75.148.235.35:56523 10.0.2.6:56523 65.61.188.4:53 65.61.188.4:53
udp 75.148.235.35:56863 10.0.2.6:56863 144.160.20.47:53 144.160.20.47:53
udp 75.148.235.35:56863 10.0.2.6:56863 144.160.112.22:53 144.160.112.22:53
udp 75.148.235.35:56863 10.0.2.6:56863 144.160.128.140:53 144.160.128.140:53
udp 75.148.235.35:56865 10.0.2.6:56865 216.239.32.10:53 216.239.32.10:53
udp 75.148.235.35:56865 10.0.2.6:56865 216.239.34.10:53 216.239.34.10:53
udp 75.148.235.35:56865 10.0.2.6:56865 216.239.36.10:53 216.239.36.10:53
udp 75.148.235.35:56865 10.0.2.6:56865 216.239.38.10:53 216.239.38.10:53
udp 75.148.235.35:57481 10.0.2.6:57481 216.239.32.10:53 216.239.32.10:53
udp 75.148.235.35:57481 10.0.2.6:57481 216.239.34.10:53 216.239.34.10:53
udp 75.148.235.35:57481 10.0.2.6:57481 216.239.36.10:53 216.239.36.10:53
udp 75.148.235.35:57481 10.0.2.6:57481 216.239.38.10:53 216.239.38.10:53
udp 75.148.235.35:57602 10.0.2.6:57602 144.160.20.47:53 144.160.20.47:53
udp 75.148.235.35:57602 10.0.2.6:57602 144.160.112.22:53 144.160.112.22:53
udp 75.148.235.35:57602 10.0.2.6:57602 144.160.128.140:53 144.160.128.140:53
udp 75.148.235.35:47639 10.0.2.9:47639 24.20.181.82:65500 24.20.181.82:65500
udp 75.148.235.35:47639 10.0.2.9:47639 31.33.116.157:17226 31.33.116.157:1722
6
udp 75.148.235.35:47639 10.0.2.9:47639 64.228.142.46:62873 64.228.142.46:6287
udp 75.148.235.35:47639 10.0.2.9:47639 66.212.214.157:13384 66.212.214.157:13
384
udp 75.148.235.35:47639 10.0.2.9:47639 67.168.146.220:63803 67.168.146.220:63
803
udp 75.148.235.35:47639 10.0.2.9:47639 67.238.11.131:58166 67.238.11.131:5816
6
udp 75.148.235.35:47639 10.0.2.9:47639 71.187.50.192:16513 71.187.50.192:1651
udp 75.148.235.35:47639 10.0.2.9:47639 81.102.82.146:18558 81.102.82.146:1855
8
udp 75.148.235.35:47639 10.0.2.9:47639 82.244.229.91:52981 82.244.229.91:5298
udp 75.148.235.35:47639 10.0.2.9:47639 83.226.168.88:50639 83.226.168.88:5063
9
udp 75.148.235.35:47639 10.0.2.9:47639 92.113.81.237:43177 92.113.81.237:4317
7
udp 75.148.235.35:47639 10.0.2.9:47639 94.71.145.119:58425 94.71.145.119:5842
udp 75.148.235.35:47639 10.0.2.9:47639 95.77.241.16:41628 95.77.241.16:41628
udp 75.148.235.35:47639 10.0.2.9:47639 98.215.229.197:18805 98.215.229.197:18
805 Pro Inside global Inside local Outside local Outside global
6
384
803
6
8
9
7
805
Total active translations: 36 (0 static, 36 dynamic; 36 extended)
Outside interfaces:
GigabitEthernet0/0
Inside interfaces:
Hits: 17152 Misses: 23343
CEF Translated packets: 33864, CEF Punted packets: 13485
Expired translations: 28772
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 pool RLH1 refcount 35
[Id: 2] access-list 2 pool RLH2 refcount 1
type generic, total addresses 1, allocated 1 (100%), misses 470
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Outside interfaces:
GigabitEthernet0/0
Inside interfaces:
Dynamic mappings:
-- Inside Source
Appl doors: 0
Normal doors: 0
Queued Packets: 0
ok I'll also stop the app on 2.9
12-08-2013 03:33 PM
Ricky,
Even if your 10.0.2.5 is your PRTG monitor, there seems to be an issue in routing: why would the packets to 10.254.254.x be routed out to public internet? It does not make sense.
You say you can not ping the internet from behind the router. What would traceroute say? Where does the traceroute stop?
Best regards,
Peter
12-08-2013 03:50 PM
well 10.254.254.1 used to be an IP of my router and as 10.254.254.x is an unknown net it would send it to the gateway of last resort (guess I never updated it to point to 10.255.255.1 instead)
from a computer I can ping
10.0.2.1 (etherswitch vlan interface)
10.255.255.2 (etherswitch vlan interface pointing to the router
10.255.255.1 (router interface pointing to etherswitch)
10.254.254.0 (router loop back interface , proving that it's routing)
but not 75.148.235.38 (ISP gateway pointing to me)
heres the tracert
1 1 ms 2 ms 2 ms rlh-ethsw.rlh-domain.net [10.0.2.1]
2 <1 ms <1 ms <1 ms 10.255.255.1
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
12-08-2013 04:00 PM
Ricky,
Thank you!
Best regards,
Peter
12-08-2013 04:55 PM
ok removed the secondaries but still can't ping from a computer
12-08-2013 05:02 PM
for testing I've now shutdown gi 1/0, 3/0 and 4/0
and changed acl 1 to include loopback1
and added ip nat inside on the loopback
I issued the follosing list of commands
int gi 1/0
shut
int gi 3/0
shut
int gi 4/0
shut
exit
no access-list 1
access-list 1 permit 10.254.254.0 0.0.0.255
int loopback1
ip nat in
so this should prevent any more nat translations other than what should occur for a ping sourced from the loopback
12-08-2013 05:03 PM
LOGIX-Router#ping 4.2.2.2 source lo 1
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Packet sent with a source address of 10.254.254.0
Success rate is 0 percent (0/5)
icmp 75.148.235.35:2 10.254.254.0:2 4.2.2.2:2 4.2.2.2:2
12-08-2013 05:08 PM
oh man am I mad at comcast now
after hours of troubleshooting the router I just power cycled the cable modem (SMC D3 acting as a pure router) and now it works
seems like it didn't want to reply to my new router for anything but the 33 till I power cycled it.
