3845 router issue ( urgent help please)
Dear Experts,
We have cisco 3845 router , we have facing the problem , we are not able to ping giga0/0 and gig0/1.
running IOS : c3845-spservicesk9-mz.124-24.T.bin.
i am not able to ping  router gig0/0 port from my pc  ( my pc ip 220.224.23.150  255.255.255.252 and gtway : 220.224.23.149)
also i am not able to ping gig0/1.1 interface from my pc ( ip 121.245.78.2 255.255.252.0 and  gtway : 121.245.78.1)
but i am able to ping fastethernet port from my pc ( ip 192.168.1.2 255.255.255.0 and gtway 192.168.1.1
nterface GigabitEthernet0/0
ip address 220.224.23.149 255.255.255.252
- ip access-group Virus-Block in
- ip access-group Virus-Block out
- duplex auto
- speed auto
- media-type rj45
-interface GigabitEthernet0/1
- description *** Connect to Cisco 3750 ***
- no ip address
- duplex auto
- speed auto
- media-type rj45
-interface GigabitEthernet0/1.1
- encapsulation dot1Q 1 native
-interface GigabitEthernet0/1.2
- encapsulation dot1Q 2
- ip address 220.224.156.1 255.255.255.128 secondary
- ip address 220.224.129.1 255.255.255.192 secondary
- ip address 220.224.39.1 255.255.255.0 secondary
- ip address 121.245.78.1 255.255.252.0
- ip access-group Virus-blok in
interface FastEthernet0/0/0
  duplex auto
  speed auto
So please experts what is the issue why i am not able to ping  both router giga port . it is IOS issue ???
Thanks in ADV,
Vaib...
Re: 3845 router issue ( urgent help please)
i am not able to ping  router gig0/0 port from my pc  ( my pc ip 220.224.23.150  255.255.255.252 and gtway : 220.224.23.149)  ----
1.For testing , can ypu remove the acl and can you try to ping the gateway
2.check the interface status of the router
3.If you are running any software firewall in your desktop, just check that or try to use some other laptop or desktop and can you try to ping.
Since this is a directly connected network,there will be no routing issue.and there no IOS issue also.
Thanks & Regards
Karuppu
Dear Karuppu,
my router giga0/0 interface directely connected to my pc no any network attach with my router only pc is attached with router gig0/0
not able to ping from my both gigabite port But when i attach router fas0/0/0 interface with my pc that time i am able to ping succefully.
so what is the issue ???
thnaks in adv.
Vaib...
For gi0/0 interface ,, can you remove the acl and can you try to ping..
and also can you paste the show interface gi0/0 output
Karuppu
D/Karuppu,
There are no any ACL config .
can it is possible there is configure on
interface gig0/0
media-type rj45   <<<-----------
interface gig0/0
media-type rj45   <<<-----------///
there is no issue of this command.
can you check your desktop firewall. might be private ip address range will be permitted so that you are able to ping and public ip address range will not be permitted so that you are not able to ping..
one more thing, can you paste the output of the below commands
sh int gi0/0
regards
karuppu
--This IP (220.224.23.150) is connected to you g0/0 interface, you cannot use this IP unless your pc is directly connected to g0/0.
--You donot have IP configured on g0/1.1 interface. Assume you want to ping g0/1.2 interface, then you need to make sure this access port on 3750 is assigned to VLAN 2.
--Make sure on 3750, the uplink to 3845 is configured as trunk port using
switchport trunk mode dot1q
swithcport mode trunk
HTH,
Lei Tian
Dear Leitian,
My cisco router 3845 gig0/0 interface derectely connected with PC only
interface gig0/0
duplex auto
speed auto
media-type rj45
no shut
My pc ip address  220.224.23.150 255.255.255.252 and default gatway : 220.224.23.149
when i ping from my pc to router gig0/0 i am not able  to ping , all the indication are perfectely shwon both side.
but when i connected with same pc to fastethernet 0/0 of this router i am able to ping successfully.
fas0/0/0
my pc ip address 192.168.1.2 255.255.255.0 and default gategay : 192.168.1.1
so what is the issue of this problem. may be IOS ??  c3845-spservicesk9-mz.124-24.T.bin.
pl help me ,
thank in adv,
Vaib...
hi,
   can you ping your system by router console port ?if yes then should off your system firewall.then you can get ping.
if not !!!!
frist you shut that interface
then go to
interface GigabitEthernet0/0
ip address 172.168.1.1 255.255.255.0
no shut
duplex auto
speed auto
media-type rj45
please check sho ip int bri
Dear Arup,
There is no any issue regarding firewall of my pc , cause i am able to ping when i connected pc with fastethernet0/0/0 of  this router that's why,
only when i connect with gig0/0 interface to connect with pc i am not able to ping.
gig0/0 is admin and protocl up
Vaib...
If you are running desktop firewall in your pc, can you disable it.because private ip address raange (10.0.0.0/8, 172.16.0.0 - 172.32.0.0/16,192.168.0.0) will be permitted by default.public ip address range might not be permitted.
or
can u assign some different private ip address in your gi0/0 and can you try to ping..hope it wil giv u the clear picture.
regards
karuppu
Dear Karuppu,
I already assigned on gig0/0 interface  ip address 192.168.2.1 255.255.255.0 and my pc ip address 192.168.2.2 255.255.255.0 and default gatway of my pc is 192.168.2.1 after still same issue not able to ping from my pc to gig0/0 and also from router to pc.
Thanks in ADV,
Vaib...
hi,
just u arrange a 10/100 switch and connect both of them.may be it should
support u.
On Mon, Feb 22, 2010 at 2:25 PM, csawest.dc <
can you paste the output of the below command (connect your pc in gi0/0)
sh int gi0/0.
i hope there is a problem in interface module..
can u attach the sh tech of the router.
regards
karuppu
hi,
May be ur system not support 10/100/1000 speed .kindly mention speed
manually
On Mon, Feb 22, 2010 at 2:37 PM, foreverkaruppu <
Dear All,
Thank you very much to all  for given me gr8 support. now i have found that issue , in this router both gig interface are faulty.
now i replce with new router.
thanks once again to all !!!
Cheers!!!
Vaib...
583
