3845 Router with 48 port fast ethernet switch module fan speeds
ive been trying to find the temperatures at wich the fans on the 3845 router will engage the highspeed fans?
as we have some of these routers installed at branch offices, and they are engaging the loud fans. we are trying to determine at what temp this is supposed to happen, so we can devise a cooling solution to keep them quiet.
Andrew
Hall of Fame Super Gold
Re: 3845 Router with 48 port fast ethernet switch module fan spe
Hi Andrew,
I believe the 3845 fan speed only has one setting: loud.
It is done on purpose to keep the components cool.
it does have variable speeds, occaisonally you would hear the router fire up louder for a few moements, then quiten down a little.
Hi, cisco specifies 58 dBa maximum:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_brochure0900aecd8019dc1f.pdf
You have to design router installation for the worst case figure. In any case, none of the ISR routers from 2801 and above are intended to be in the same area as humans.
Hi Andrew,
You are not talking about during the startup or bootup process are you?
307
