3925E Wont Adress translate
Hello i have a couple of 3925E routers running HSRP both internaly and externaly.
I cant get them to NAT the traffic though. They just route it out.
I also tried to connect via VPN to se if that worked and it didnt.
Im poundering where im going wrong with this.
Here is the relevant config.
Router1.
interface Port-channel1.62
encapsulation dot1Q 62
ip address 10.56.0.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip nat inside
ip virtual-reassembly in
standby version 2
standby 12 ip 10.56.0.1
standby 12 priority 110
standby 12 preempt
interface Port-channel1.63
description $FW_OUTSIDE$
encapsulation dot1Q 63
ip address x.x.x.135 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
standby 1 ip 193.182.225.134
standby 1 timers msec 500 2
standby 1 priority 110
standby 1 preempt
interface Port-channel1.64
description $FW_DMZ$
encapsulation dot1Q 64
ip address 10.56.2.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
standby 2 ip 10.56.2.1
standby 2 timers msec 500 1
standby 2 priority 110
standby 2 preempt
interface Virtual-Template1 type tunnel
ip unnumbered Port-channel1.63
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
ip nat pool Dynamic x.x.x.137 x.x.x.139 netmask 255.255.255.252
ip nat inside source list 1 pool Dynamic
access-list 1 permit 10.56.2.0 0.0.0.255 log
access-list 1 permit 192.168.46.0 0.0.0.255 log
access-list 1 permit 192.168.40.0 0.0.0.255 log
access-list 1 permit 192.168.49.0 0.0.0.255 log
access-list 1 permit 10.56.0.0 0.0.0.255 log
access-list 1 permit 10.56.1.0 0.0.0.255 log
Router 2
ip address 10.56.0.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
standby version 2
standby 12 preempt
ip address x.x.x.136 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
standby 1 preempt
ip address 10.56.2.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
standby 2 preempt
interface Virtual-Template2 type tunnel
ip unnumbered GigabitEthernet0/0
ip nat inside
tunnel protection ipsec profile CiscoCP_Profile2
I cant get it to NAT. Im pressuming im doing something wrong but im lost as to what.
Everyone's tags (2)
Re: 3925E Wont Adress translate
Iam not sure if nat inside and outside will work using same interface with sub-interfaces !!
You can try to use NAT on stick and see if dose fix your issue
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094430.shtml
Hope this help
Hummm changed the external interface to a physical port on both routers still the same thing.
It refuses to NAT im poundering bug or something. Any1 else with some tips? Am i doing something obviously wrong or what gives...
Hello.
Tried some more things.
When i change so that i have one adress in the dynamic pool that matches the Virtual ip of the HSRP cluster it seems that my NAT starts to work.
Seems that i cannot translate to different adresses dynamicly when using HSRP? Someone recognise this issue?
655
