3G connect with Failover
Hi2All
SP is proposing Wireless WAN for backup connectivity for existing Wired connection, i.e 3G connect for branch office connectivity. Recommended router is 1841. Can I get configuration assistance for 3G to act as failover for primary link. 3G connection would be over public network and need to establish ipsec gre tunnel. OSPF is dynamic routing protocol
best wishes
Anthony
1 REPLY
Bronze
Re: 3G connect with Failover
You require generic backup interface configuration with "backup commands" on the Cellular interface.
Pls refer the config guide below.
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwlsgsm.html#wp1237405
The above link gives backup DDR for Cellular interface as primary. But the same approach you can follow to configure the cellular as backup to a primary interface.
Hope it helps...
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
255
