3G GSM module configuration
I have problem with HWIC-3G-GSM configuration. The cellular interface doesn't get IP from ISP.
The configured profile is always inactive.
Please find attached files.
cellular 0/2/0 gsm profile create 1 m2m.plusgsm.pl chap plusgsm plusgsm
Hall of Fame Super Silver
Re: 3G GSM module configuration
Hello WKamil123,
you have probably solved
under cell0/2/0 interface you should add
ppp authentication chap
Hope to help
Giuseppe
Hello Giuseppe,
Thank's for your replay. I solved my problem and  I works now.
Regards Kamil
Can you post your known-working configuration? Thanks.
~Brian Seklecki
1328
