Community Member
3G wireless card help
We have gotten a 3G wireless card for a 2811 router we have with service through Verizon. I have activated the card and it appeared to work. Doing a show Cellular all I can see the phone number and the username and everything. However, I am not seeing an IP address. We were assigend a static but it's still not showing up. Here is my config for the card...
interface Cellular0/1/0
ip address negotiated
encapsulation ppp
dialer in-band
async mode interactive
ppp chap hostname
ppp chap password 0 vzw
ppp pap sent-username password 0 vzw
I obviously changed the number. Anybody dealt with this before that could give some pointers? Here is my show interface...
Cellular0/1/0 is up (spoofing), line protocol is up (spoofing)
Hardware is EVDO Rev A/Rel 0/1xRTT-800/1900MHz / VZ
Internet address will be negotiated using IPCP
MTU 1500 bytes, BW 1800 Kbit/sec, DLY 100000 usec,
Encapsulation PPP, LCP Closed, loopback not set
Keepalive not supported
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1350 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=down RTS=up CTS=up
Hall of Fame Super Silver
Re: 3G wireless card help
Hello Dennis,
I would add
ppp authentication chap pap
you have configured the parameters to be used but not to use authentication
you can debug as usual with
debup ppp neg
debug ppp auth
you need to see LCP open IPCP open LCP closed means the ppp session is stopped
Hope to help
