4-Port HWIC and 9-Port HWIC on ISRs
Could anyone tell me if the above mentioned HWICS are configurable as routed ports. I would like to assign an IP per port ?
Gold
Re: 4-Port HWIC and 9-Port HWIC on ISRs
No you cannot assign ip's to the ports they are switch ports.
You can however put each port in its own vlan and create vlan interfaces and put ip's on those.
There are some small differences between the vlan interfaces and true router interfaces but in general they will work the same.
Thanks for your help !
220
