Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
4 Port Serial Adaptor
Hi All,
We have 7200VX series router which has 4 port -PA 4T serial adapter.If we populate each port with an E1, then is possible to route all the bandwidth into the LAN through a single Ethernet port,or do we need 4 Ethernet ports.
Thanks in advance.
Re: 4 Port Serial Adaptor
Hi Ravinder,
4x E1 lines have a bandwidth of 4x2048 kbits/s which is 8192 kbits/s (8.192 Mbits/s).
An Ethernet port has 10Mbits/s so it should be able to handle that traffic.
A problem may arise if the Ethernet port connects to a shared Ethernet segment saturated with traffic.
In this case the Ethernet port will not have its entire bandwidth available.
But if the Ethernet port connects to a switch with higher speed uplink ports then I think there should not be a problem.
Cheers:
Istvan
Hi Istvan,
Thank you very much for your reply.
If we connect the ethernet port to a Cisco 3500 Catalyst then we should not face any problem.?
I would also like to know how do we do routing in this case.we plan to use static routes.
Hall of Fame Super Silver
Hello Ravinder,
it is very important to setup a 10 Mbps full-duplex link:
half-duplex supports up to 3.3 Mbps per direction.
So verify the ethernet port is capable of full-duplex I remember some PA with 4 Ethernet or 8 ethernet ports not capable of full-duplex operations.
Once this is solved you can use static routes
Hope to help
Giuseppe
93
