Community Member
4500 Gigabit input errors
When I do a show interface on a GigabitEthernet interface I am getting input errors with no other errors.
Any ideas what could cause the problem?
554273 packets input, 528085705 bytes, 0 no buffer
Received 84 broadcasts (0 multicast)
14 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
413557 packets output, 59392742 bytes, 0 underruns
0 lost carrier, 0 no carrier
Re: 4500 Gigabit input errors
there are a few reasons a packet can be dropped and noted as an input error:
cable damage, cable removal/addition to port/interface, internal hardware failure, port/interface configuration to name a few...
try a different cable if these continue to persist.
i see that out of 554,000+ packets only 14 were dropped due to input error. (zero of these due to no buffer avaiable) this is a very small number and if it is not incrementing then i would not worry about it too much, could be the cable was removed/reinserted during operation. again, check the cable and replace if you see these incrementing.
