Community Member
4500 PDLM RTP Audio
Hello Guy's/Gals
Im trying to locate the PDLM for the RTP audio for the 4500 series switch,
System image file is "bootflash:cat4500-entservices-mz.150-2.SG.bin"
cisco WS-C4507R+E (MPC8245) processor (revision 7) with 524288K bytes of memory.
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
8 Virtual Ethernet interfaces
48 FastEthernet interfaces
100 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
It seems to be an easy task for routers:
http://www.cisco.com/cisco/software/type.html?mdfid=268437991&flowid=7410
But not for these 4500's
http://www.cisco.com/cisco/software/type.html?mdfid=277241602
if any one could point me in the right direection it would be appricated.
Cheers Neil
Regards Neil http://uk.linkedin.com/pub/neil-grant/20/5b0/267
Everyone's tags (6)
1 REPLY
Community Member
4500 PDLM RTP Audio
I have now decided i will try to install an old PDLM from a 1800 series, only to find out that it looks like it is unsupported?
4500
XXXXXXconfig)#ip nb
Lab
R1(config)#ip nbar pdlm ?
  WORD  Full path of the PDLM file
oh Joy, does this mean that i will have to match every possible codec by an access list?
ie
! Access List Example (You identify VoIP Control  traffic)
permit tcp any any eq 1039
permit tcp any any eq 1720
permit tcp any any eq 1731
permit tcp any any eq 2945
permit tcp any any eq 3230
permit tcp any any eq 3231
permit tcp any any eq 3232
permit tcp any any eq 3233
permit tcp any any eq 3234
permit tcp any any eq 3235
permit tcp any any eq 5010
permit tcp any any eq 5012
permit udp any any eq 1718
permit udp any any eq 1719
permit udp any any eq 3230
permit udp any any eq 3231
permit udp any any eq 3232
permit udp any any eq 3233
permit udp any any eq 3234
permit udp any any eq 3235
permit udp any any eq 5005
! Access List Example (You identify RTP Audio traffic)
ip access-list extended 105
permit udp any any eq 2048
permit udp any any eq 2050
permit udp any any eq 2052
permit udp any any eq 2054
permit udp any any eq 2056
permit udp any any eq 2058
permit udp any any eq 2060
permit udp any any eq 2062
permit udp any any eq 2064
permit udp any any eq 2066
permit udp any any eq 2068
permit udp any any eq 2070
permit udp any any eq 2072
permit udp any any eq 2074
permit udp any any eq 2076
permit udp any any eq 2078
Any help as per before would be good.
NG
500
