4948 10GIG
Gerard Gacusan
does the 10gig port on 4948 is hard-coded? meaning you can't change the duplex to 1gig, correct?
that means, no way around to establish a connection to a 1gig port for uplink.
5 Replies 5
jphilope
Level 3
Level 3
You cannot change the port speed to less than 10 gig. It must connect to another 10 gig Xenpack. You cannot connect a 10 gig Xenpack to a SFP or GBIC.
I hope this answers your question.
Jim
yup, that answer my question. I just need to confirm and I have same thought too.
thanks jim.
gerard
Joseph W. Doherty
Not supported currently, but perhaps some time in the future the TwinGig model will be supported in the 4948-10GE X2 slots.
I have recently bought a load of these switches.. They came with a twin gig sfp converter for an X2 slot. Model number is CVR-X2-SFP V01
I don't know if its supported or not, but it would seem strange that Cisco sent these with the switches without them being supported.
I haven't tested them as I put 10Gig interfaces in.
yandy_ramirez
the C3560E is another option that supports TwinGig if you're interested.
