Webcast-Catalyst9k
5400 CDR
we have cisco 5400 with 16 PRI and connect to different providers. We check the CDR of 5400 and it does not include the PRI circuit and channel info. How do we enable it? please advise.
Best regards
1 REPLY
Silver
Re: 5400 CDR
The Call Detail Record (CDR) format? The CDR format has been modified to include three additional attributes: trunk group, call ID and start/stop flag.
The trunk group is the name of the Trunk Group through which the call was accepted.
The call ID is a unique string that identifies the particular call.
The start/stop flag indicates whether the CDR was generated at the beginning (resource allocated) of the call or when the call was terminated (resource freed).
CDR generation when a call is initiated?In RPMS 1.0.x, CDRs were generated only when a call was terminated. Cisco RPMS 1.1 can be configured to generate CDRs at the beginning of a call as well. When start and stop CDRs are generated for a call, both of them have the same call ID.
120
